Touran dash and electric window conversion.
LewisOram11
Post by LewisOram11 » Sat Nov 21, 2020 6:44 pm
Hi guys just bought a Touran dash and the electric window conversion for my caddy 2008. Does anyone have any advice on fitting them and what i might occur while doing it.
Cheers.
Sean1066
Re: Touran dash and electric window conversion.
Post by Sean1066 » Sat Nov 21, 2020 7:51 pm
Take your time and make sure you have all the parts that you need.
Look at blackberry build thread he has done a how to on his
My build thread
C Chis
Post by C Chis » Sat Nov 21, 2020 8:30 pm
As Sean has said, take your time and enjoy it!
Isolate your battery and remove your steering wheel before you start.
And if it doesn’t pull away from the window easily then you’ve still got a screw/bolt or two still to remove.
Oh, and remember to disconnect the temperature sensor on the RHS next to the A pillar.
Also a good idea to run the additional power wire to each of the A pillar door connectors while you have the dash out and use the Touran wiring harnesses when your converting your windows to electric.
You’ll also need to modify the top corner of the door cards where they meet the mirror cover as they are slightly different on the Touran
My MTB Caddy Build Can be Found Here
LewisOram11
Post by LewisOram11 » Sun Nov 22, 2020 6:45 am
Awesome thanks for the help. Luckily the van isn’t on the road at the moment so time is on my side and I’ll be taking it slow. And also now thanks to yous I’ve got some more information about the conversion than I knew before.
LewisOram11
Post by LewisOram11 » Sun Nov 22, 2020 6:46 am
LewisOram11
Post by LewisOram11 » Sun Nov 22, 2020 7:23 am
Thanks I’ll take a look at his build thread.
LewisOram11
Post by LewisOram11 » Sun Nov 22, 2020 12:19 pm
Is there a diagram any where to show where the additional power wire runs from and where it goes to?
C Chis
Post by C Chis » Sun Nov 22, 2020 12:26 pm
Hi buddy, yeah, there’s a good how to in the technical section.
Once your upgrade comes through in a few days you’ll have access to it
LewisOram11
Post by LewisOram11 » Sun Nov 22, 2020 12:40 pm
Once your upgrade comes through in a few days you’ll have access to it Image
apriliajimmy
Post by apriliajimmy » Sun Nov 22, 2020 12:49 pm
I made a template with masking tape off the original door cards for the cutting. Only problem I have now is with the locking module wiring. I probably need different motors / modules. Image
Sent from my WAS-LX1A using Tapatalk
LewisOram11
Post by LewisOram11 » Sun Nov 22, 2020 6:10 pm
I’ve seen that a small section needs to be cut out for the inside mirror part. The main thing is the extra wiring needed for it to work.
apriliajimmy
Post by apriliajimmy » Sun Nov 22, 2020 6:15 pm
LewisOram11 wrote: I’ve seen that a small section needs to be cut out for the inside mirror part. The main thing is the extra wiring needed for it to work.
For me there is because the central locking does not work because the electric motor and locking module is one part. So I'm not sure on what I got to do at the moment. Plus the motors I have are from a 07 touran my van is a 12. So depends on what motors you get as well
