RallyeS2
Post
by RallyeS2 » Fri Dec 11, 2020 10:03 am
Hi all
Anyone try or have installed VW Golf 7 R steering on VW Caddy 2K?
Is it possible to work all 100%? This Caddy have Golf 5 full FIS cluster.
I appreciate any feedback or help possible
BR
Post
by Doc » Fri Dec 11, 2020 10:14 am
Hi,
Yes it can and has been done, lots of forum members have this.
Your mk5 full FIS will make no difference, it is the same as Caddy/Touran in so far as steering wheel control requirements.
RallyeS2
Post
by RallyeS2 » Fri Dec 11, 2020 1:56 pm
Great to know that's possible. The question is how
Anyone have any tutorial/help documents to start make this happen?
Thanks. BR
Giddy
Post
by Giddy » Fri Dec 11, 2020 2:45 pm
Oh yes, lots of info here, one you get access. Will keep you busy for quite a bit to read and process it all
RallyeS2
Post
by RallyeS2 » Fri Dec 11, 2020 3:23 pm
Ohh no problem
If is here, i will read and learn and maybe help in the future
Michel R32
Post
by Michel R32 » Mon Dec 14, 2020 12:28 pm
As far as i know, this can only be done with steering wheels that have golf mk7 look, from vw polo 6C and scirocco 2016and up
RallyeS2
Post
by RallyeS2 » Fri Dec 18, 2020 1:02 pm
Thanks for your input Michel
I saw also some Xhorse module that can work with the wheel.
Link:
http://xhorse.uk/product/mfsw-module-en/
Also MFDColor3D have other module that work, but i'm study the problem to put this mfsw working
Ripley55
Post
by Ripley55 » Fri Dec 18, 2020 2:29 pm
I used Polo wheel as I wanted to keep the buttons Red
Chestnut Brown Caddy MK4 Maxi Life 2.0Tdi 150bhp , 19" ZEUS Alloys 8.5J, 235/35/19's
caddy4mo
Post
by caddy4mo » Sun Mar 14, 2021 11:14 pm
Where do you buy these steering wheels?
Post
by Doc » Mon Mar 15, 2021 1:18 am
There are many sources for mk7 steering wheels. New from VW and even some online auction sites. Used, again the online auction sites are a good source or you could look at breakers yards local to you or even online.
caddy4mo
Post
by caddy4mo » Mon Mar 15, 2021 3:54 am
Thanks Doc,
Your alternatives are given though.
I was thinking more of webshops etc.
Cheers.
Doc on Mon Mar 15, 2021 3:54 am, edited 1 time in total.
Post
by Doc » Mon Mar 15, 2021 5:20 am
I tend to stay clear of websites selling genuine VW parts as they'll be buying the parts from VW who you can go direct to yourself and cut out the middle man.
son of eevil
Post
by son of eevil » Mon Mar 15, 2021 4:35 pm
Also interested in doing this, is it only the MK7 and up that it works with you can you go to earlier cars?
Alex mc
Post
by Alex mc » Mon Mar 15, 2021 5:34 pm
Hi all sorry to jump in I’m looking to do this on my Mk 4 caddy start line using the polo mfsw . After reading some posts / threads on the forum am I right saying this swap is more straightforward. I’m guessing reading them most of the swaps have been retro fitted to mk3 etc with bit higher spec than mine. I found 1 for my 4 but it was higher spec than mine . I couldn’t find one for my spec van . My question is will I still need module new stalks etc to do this? Which would I need if had to do it .I just don’t want to get stung online buying wrong part etc . I unfortunately don’t have VCDs to pull out info of what’s there. I like doing things myself if and if it is straight forward enough to change over I would change the bits and pay someone to code it all in. any help would be greatly appreciated
Ro-Touran
Post
by Ro-Touran » Wed Apr 07, 2021 12:13 am
Michel R32 wrote: ↑Mon Dec 14, 2020 12:28 pm
I was wondering what are the necessary steps and or parts to make the make the cruise control work if i get my hands on 1 of these wheels?
Touran 1T3 2.0 TDI
