Whats involved in the single to double wiper swap? Is it a simple swap over and plug and play with the loom?
I had to replace a front coil spring and when I removed the scuttle it all broke up so am thinking of the swap over at this point.
Wiper motors
Re: Wiper motors
Quite simple if you've got the parts and the additional bracket on the passenger side.
You just need to adapt the wiring harness to link both motors.
Re: Wiper motors
Hi Doc, will it not be easier to take the twin motor loom and plug that in?
Re: Wiper motors
Nah, I wouldn't go replacing the entire loom from head to tail lights, it's not a bit task to splice in the link across from one motor to the other.
Re: Wiper motors
Ok, thanks.
