Well the Aerial I got has fitting for both.
And it works really well for both.
Aerial wiring
- Cabbs
Re: Aerial wiring
A Dab Ariel is the way to go. Just have to drill a hole in the roof and put some grease around the bit that screws in to make it water sealed. then run cable from back to front. It is a bit fiddly but not too bad. And Dab is great to have.
Re: Aerial wiring
Shark fin fitted, just need to wire in the power.
Heat controls seems to have an ignition live, tempted to tap into that.
Re: Aerial wiring
Better to run a clean feed from the fuse panel for the sake of a extra couple of feel of wire.
Re: Aerial wiring
The cable isn’t long enough but you are right.
Just need some cable and some connectors. More money and another job I can’t do till they arrive.
