Maxi roof bars
Maxi roof bars
Hi may have been covered before but I can’t find anything on here. I have Caddy Maxi and have been looking at roof bars but can’t seem to find any it only has 3 bolts on the roof the one at the back just has indentation no bolt. Do I just go for SWB ones or isn’t the end nearest the back doors bolted down....and just go for the maxi ones...any ideas
- Nemox
Re: Maxi roof bars
What year is your maxi? My 2015 maxi had 8 mounting points in total, 4 on either side.
Re: Maxi roof bars
my MY17.5 maxi also has 4 on each side.
Re: Maxi roof bars
Thanks for the replies it has 3 bolts either side mine is 09/59...
Re: Maxi roof bars
Is it because mine is a earlier one that it only has 3 bolts and you can’t fit roof bars that run the length of the van. I’ve seen a couple of Caddy’s lately with what looks like the bars are fastened across the width of the roof not the length
- Cthulu
Re: Maxi roof bars
Mines a 2015 maxi
Came with an unwanted lateral roof rack and 8 mounting points
Had a crack at taking it off today. Rubbers are shot so will be hunting replacement bolts in the morning
Mercifully clear night tonight
Caddy 140 6 speed with scum class Startline spec
BC coil overs. Whiteline adjustable ARB. MAM RS4 19” alloys on Pilot Sport 4S tyres. Sirus rear seats. Darkside tune 190bhp
Re: Maxi roof bars
Hi do you have any idea which type of roof bars were taken off? I’m looking to add some to my 2015 ex BG which has 8 holes on the roof
