Hi Guys.
Carista is very good bought one a few months ago well worth it, also now having the option for DPF force regen which is super helpful is you haven’t had the DPF delete
Which to buy Carista OBD Eleven or Carly ?
Re: Which to buy Carista OBD Eleven or Carly ?
Hi Guys.
For vag cars i think obd eleven is the one to get. Allows you to do a lot more than what the carista can.
I've had both and although a bit more complex to use but once you get used it you will reap the rewards.
Can do all sorts on my car and van.
+1 for vcds. It's amazing how useful it's been, and how many new friends you get when you have it.
Does anyone know if obdeleven can code in new injectors?
Yes, I used my obdeleven to code them on my van along with other bits. Brilliant bit of kit that I keep in the van all the time for those just incase moments.
Vcds if budget allows.
But OBDeleven is just as powerful
