Renewing the coolant ???
Dear colleagues of the forum,
•Do you know what pressure is in the coolant circuit of the main coolant radiator?
•Is any additional step necessary in the control unit when renewing the coolant?
•Do I drain all the coolant with the valve and replace it, or is it necessary to take it to the service station and have it done by them?
Thanks for all the information you provide !!!!
Re: Renewing the coolant ???
I believe the coolant cap is a 6 bar version as standard across all Caddy2k.
There is no need for diagnostic equipment when changing coolant, just drain and refill. The system will bleed out air as the engine is running, you might need to top up the reservoir after it has heated and cooled down again for the first time.
Just out of interest Doc, would disconnecting the bottom hose on the radiator be the best way. I assume there’s no drain plug?
I've never seen a drain plug for the coolant on a Caddy. Any time I've drained the coolant it's just been a case or removing the lowest point on the pipework.
Once the level drops, you can remove other connections to get as must as possible out.
Got you mate. The thread just piqued my interest as it’s a job I’ll surely do at some point.
I unclipped the bottom hose,
when doing the timing belt,
caught the coolant in a bucket
and put it back in when all done ..
May be a good idea also to flush it through with water before filling up properly to make sure it’s all clean,
Had to do it on mine but make sure you drain it once the thermostat has opened and only flush the system once the engine has cooled down so that you don’t crack the block
Is the process the same with the water intercooled system (CUUD diesel) as there are two radiators to worry about?
Hi guys,
I have questiont regarding coolant, so i will ask here:
Which type of coolant should I use for my 1.6 tdi CAYD 2013?
On my coolant reservoir is the notice that G12 coolant is the right one. But in my caddy manual is infor that the system is fulfill with G13 coolant (TL-VW 774 J).
Which is the right one, or which is better if both can be used.
Thanks a lot in advance.
Strange ! How un-German !!
My reservoir also says G12 - Printed on at manufacture.
But my manual clearly states refill with distilled water and 40% G13 or at least G12++ (both purple).
Mixing with G12, G12+ or G11 will significantly decrease level of corrosion protection.
Wolf Lubes - What you need to know about G13 antifreeze and coolant
Quote Manual
Quote Manual
Coolant specification
The cooling system is filled at the factory with a mixture of specially prepared water and at least 40% coolant additive G 13 (TL-VW 774 J).
The proportion of coolant additive must always be at least 40% to protect the cooling system. I greater frost protection is required in very cold
Coolant and coolant additives can pollute the environment. Spilt service fluids must be collected then disposed of properly and in an environmentally responsible way.
Checking the coolant level and refilling coolant
Please refer to A and on page 238 and A at the start of the chapter on page 247
climates, the proportion of anti-freeze additive can be increased. However, the percentage of coolant additive should not exceed 60%, as this would reduce the frost protection and the cooling effect.
The coolant additive is dyed purple. The mixture of water and a coolant additive offers anti-freeze protection down to -25°C (-13°F), protects the alloy parts in the cooling system against corrosion, prevents limescale deposits and significant ly increases the boiling point of the coolant.
When refilling the coolant, a mixture of distilled water and at least 40% coolant additive G 13 or G 12 plus-plus (TL-VW 774 G) (both of which are dyed purple) must be used in order to obtain the optimum corrosion protection @.
Mixing G 13 with the coolant additives G 12 plus (TL-VW 774 F), G 12 (dyed red) or G 11 (dyed blue-green) will significantly decrease the level of corrosion protection and should therefore be avoided.
I have the same text in my manual.
So there is a question
Yes, definitely a question.
I think the manual and link address it by saying
G13 or G12++ safe to mix. All others reduce corrosion protection if mixed with 13 or 12++.
G13 is better for the environment, but G12++ is equally effective.
Only use distilled or de-ionised water.
Actual experts can no doubt confirm or deny what I am reading.
Got to admit on any of my vehicles I've never used distilled water and the only spec of coolant I've looked at is what temperature it freezes at.
Maybe on my new one I should be using the recommended 'juice' lol.
