Caddy mk4 boot lid handle actuator with camera* frozen
Marin97
Post by Marin97 » Wed Mar 10, 2021 9:19 am
With this cold wather in my country there was a bit of rain during day. Temps below 0 so freezing. In the next morning I tried to open boot (big single door version) with no success, as it seems water is inside that little handle and I couldn't press a micro switch.
PN is: 2k5827566c
So I went to dealer as I have warranty and said what happend. They said it is okay and they can't find problem.
Anyone had this? Where could water come from? I'm thinking third stop light, or near part itself? Number plate lights?
Unfortunately there will be, I think, no more freezing temps so I can't prove it froze.
Help any ideas welcome!
Poslano sa mog SM-G960F koristeći Tapatalk
:mrgreen: :mrgreen: Caddy VAN 2017 TDI DSG 6-speed 102hp :mrgreen: :mrgreen:
Pics:
https://ibb.co/album/8bB8TJ
Marin97
Re: Caddy mk4 boot lid handle actuator with camera* frozen
Post by Marin97 » Wed Mar 10, 2021 9:38 am
And I think it will froze again next winter, but out of warranty then.
Pics:
Scoobysrt
Post by Scoobysrt » Wed Mar 10, 2021 12:34 pm
Are you sure it's the button? When my 06 used to do it the rubbers were at fault, a bit of vaselene on them and it didn't happen again.
Marin97
Post by Marin97 » Wed Mar 10, 2021 1:13 pm
Sorry, didn't understand that, where to put vaseline, on outside of handle or inside?
The ting is that I couldn't get handle to do click, i couldn't get lock to activate and open.
Pics:
C Chis
Post by C Chis » Wed Mar 10, 2021 1:28 pm
I had a similar issue a few weeks back with the handle moving but not engaging with the lock. I had to pull the handle down a little until I heard a click and then it worked for a while.
I removed the interior panel and lubricated all the pivot points from the handle to the lock a little spray silicon grease/oil and now everything works perfectly.
2010 pre-facelift Mk3 1.9 Remapped BLS : Touran Interior : 3D Premium Clocks : R32 Bumper : Climatic A/C : Stealth Xenons
My MTB Caddy Build Thread and Details can be Found Here
Scoobysrt
Post by Scoobysrt » Wed Mar 10, 2021 3:18 pm
Vaselene on the rubbers, as I said its often the actual rubbers sticking and not the lock and although the locks do stick sonetimes I've never heard of the micro switch on the back not being able to be pressed in.
I was just questioning if it was the actual lock not working or if it was the door not opening.
Marin97
Post by Marin97 » Wed Mar 10, 2021 8:12 pm
Thanks all for answers, i think there was water in handle and it froze and it created a barier between rubber and inside plate and between plate and micro switch...
Thats my opinion. I'll get back with results..
Pics:
Scoobysrt
Post by Scoobysrt » Wed Mar 10, 2021 10:31 pm
OK, I see. I thought it was a sealed unit. Keep us posted.
Innes Buchanan
Post by Innes Buchanan » Sun Mar 14, 2021 10:06 am
I have had that on the Caddy and on my other car a Peugeot 2008. Just some rain water into the handle from outside, it freezes, and the handle mechanism will not work unless you give it a hard pull. There are two products I use at the start of winter, both available on Amazon. Holts or similar silicone spray into the handle mechanism, and hinges if they are exposed. Don't use products that are not pure silicone as they have things like graphite added, which can make a mess. Then Sonax GummiPfleger on the rubbers which get tacky and stick in the cold weather. Don't use vaseline type of products as they are not made for rubber and apart from being messy can have long term detrimental effecxcellent product s made for the job, and worth what they cost
Marin97
Post by Marin97 » Sun Mar 14, 2021 10:08 am
Okay cool! But my main concern is where water is coming from?
Pics:
C Chis
Post by C Chis » Sun Mar 14, 2021 11:04 am
Most likely to be water ingress around the high level/third brake that is pooling down in the cavity or seeping in around the door handle. It would be worthwhile removing the interior cover and having a look to see if you can spot any telltale signs of water/rust, etc...
Marin97
Post by Marin97 » Sun Mar 14, 2021 11:05 am
Will do thanks!
Pics:
Marin97
Post by Marin97 » Fri Apr 02, 2021 10:12 pm
Update:
Vw dealer sealed everything after rain check, should be all good now, well see how it wil hold next winter, if it frizes again, i will have to do things myself as car isnt in warranty anymore.
Thanks everyone!!
Pics:
