Has anyone fitted a tailgate inside opening handle, so you can open the boot from the inside? I’ve got a mk4 maxi life 7 seater.
The part number appears to be 2K0829309, but I can’t see any instructions online on how to connect it.
I’m open to ideas, if there are other solutions. I’ve even seen some people run fishing wire to a pull pin about the rubber tailgate handle.
Cheers!
Tailgate handle retrofitted?
- Giddy
Re: Tailgate handle retrofitted?
Hi and welcome to the forum.
Tailgate lock is electrically controlled as far as I know. The part number is for a barn door, which is mechanical and won't be compatible.
Check this thread where a forum member installed a switch viewtopic.php?t=42330
I think I saw someone on a forum here who’d just drilled a hole and attached a pull chord to the latch. So it sounded like it’s an option. But you could be right that it’s mechanical!
I saw T6 owners have fitted handles in their tailgate, like so:
Would this be possible?
- Papa Bear
Small non latching electrical button wired into the catch does the job. There are write ups on here somewhere, I’ll see if I can find it, sure I bookmarked it
Edit: https://www.caddy2k.com/forum/viewtopic ... on#p355076
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Cheers Papa Bear! That’s a top link tip.
Just had a poke about behind the tailgate panel and this white switch seems to manually unlock the boot. So I wonder if the handle & wire method would do it, to open from the inside?
Reason: Edited picture link
