Mk4 LED repeaters (indicators)
Ripley55
Re: Mk4 LED repeaters (indicators)
Post by Ripley55 » Sun Mar 28, 2021 4:56 pm
No worries mate, hope you get it sorted 👍
Chestnut Brown Caddy MK4 Maxi Life 2.0Tdi 150bhp , 19" ZEUS Alloys 8.5J, 235/35/19's
Bad666
Post by Bad666 » Sun Mar 28, 2021 4:57 pm
That’s mine from back.
Scoobysrt
Post by Scoobysrt » Sun Mar 28, 2021 6:25 pm
Mine were from van style as well,
Scoobysrt
My invoice says dynamic flash your invoice says standard flash. I also paid more.
There's something amiss somewhere.
I'm guessing mine end in 21 because they are clear, you two have smoked which could explain the 22.
Bad666
Post by Bad666 » Sun Mar 28, 2021 6:31 pm
Yes I think the LG means code for resister or something.
Scoobysrt
Post by Scoobysrt » Sun Mar 28, 2021 6:32 pm
It would make sense. See what they say and let us know 8)
Bad666
Post by Bad666 » Sun Mar 28, 2021 6:32 pm
I will Image 8)
Scoobysrt
Post by Scoobysrt » Sun Mar 28, 2021 6:42 pm
I actually think as according to your invoice, you bought standard flashing ones. The code on the box will have LG for the dynamic ones.
I think someone has put dynamic ones in the standard flashing box by mistake and there will be a box of dynamic ones labeled with an LG with standard flashing ones in.
That box will still have the resistors in it and another owner will be scratching their head why they have the resistors lol.
Bad666
Post by Bad666 » Sun Mar 28, 2021 6:46 pm
Ha ha the resisters seem to be built into wiring so I don’t think on you can go wrong? Can you?
Scoobysrt
Post by Scoobysrt » Sun Mar 28, 2021 10:48 pm
I honestly can't remember, I thought mine plugged in to the plug and were separate in the box.
Infact I'm sure they plugged in as I was deciding what they were and if I should use them or not then I guessed they were caps or resistors to stop the dash showing an error up.
Edit, Actually I'm not sure at all my mind could be playing tricks, I see ripleys were hard wired so I just don't know.
Bad666
Post by Bad666 » Mon Mar 29, 2021 9:43 am
Right! Spoke to van style . Recon these can be coded out. Is that an option or is there a resistor I can by and add? Or do I send back and get proper one ?
Post by petrev » Mon Mar 29, 2021 10:17 am
Send back and get proper ones !
Can't remember seeing any coding for repeaters.
May be there, if so Doc or other VCDS expert will chime in.
There may be some EPROM recoding, but that would require some other tools !!!!
Bad666
Post by Bad666 » Mon Mar 29, 2021 10:20 am
Ok thanks . Might just send back TBH shouldn’t have to do this.
Post by petrev » Mon Mar 29, 2021 11:07 am
Travelin-Lite are normally very good on the service front. Always have been for me.
They should send you out the correct version and pay for the return of the incorrect item.
I have dealt with - emma at travelinlite dot net
Bad666
Post by Bad666 » Mon Mar 29, 2021 11:32 am
Thanks. They did admit I’d been sent the incorrect lights I ordered standard flash, and the night rider one was sent .
Think I’ll just get returns label like he mentioned and send back. And order from travel-lite.
Thanks Again.
Ant
