What turbo is this??
Leeoncupra
Post by Leeoncupra » Wed Mar 31, 2021 11:53 pm
Hi
Just curious if anyone knows what turbo this is fitted to my 08 caddy with pd130 conversion
Looks like it sits up quite high??Image
Re: What turbo is this??
Post by Doc » Thu Apr 01, 2021 12:23 am
If someone who's never seen in your engine bay can identify the turbo from that photo, I'd be flabbergasted.
You be better getting a close-up of the turbo from different angles, there's got to be a plate on there to identify it.
Leeoncupra
Post by Leeoncupra » Thu Apr 01, 2021 10:44 am
Hi doc sorry
I've never seen one with that style of inlet before , it looks really high up and different to standard turbo set ups
Il get under and have a mooch for any numbers
Post by Doc » Thu Apr 01, 2021 11:24 am
The inlet manifold is not part of the turbo.
Nelson w124
Post by Nelson w124 » Fri Apr 02, 2021 12:10 pm
2.0 tdi BMN 170cvs??
Leeoncupra
Post by Leeoncupra » Fri Apr 02, 2021 12:14 pm
Turbo is a garret gt1749 found the number on it , just the inlet manifold looks different which thrown me off
Having an issue with a stutter at 3k on full throttle so trying to figure out what parts are on it and the turbo stumped me
Post by Doc » Fri Apr 02, 2021 12:19 pm
GT1749VB is the standard PD130/150 turbo.
You'd be best getting some diagnostics logs and see what fuel, boost etc is doing, that'd help point you at your problem.
Leeoncupra
Post by Leeoncupra » Fri Apr 02, 2021 12:42 pm
Thanks doc
That will be my next step
shanky887614
Post by shanky887614 » Fri Apr 02, 2021 8:02 pm
its either a bv39, pd170 turbo or a hybrid of some kind
Leeoncupra
Post by Leeoncupra » Fri Apr 02, 2021 8:08 pm
Thank you
I cant get access to vag comm to do some logging
The van has a misfire/stutter at 3k rpm
It even does it in neutral at stationary
It's fine before and after, religiously everytime the needle hits 3000 it does it
Is there any possible parts I should look into changing or focusing my attention on , I will go down the trial and error route , the engines I'm genuinely familiar with are the pd170s and 2.0tfsi's
Scoobysrt
Post by Scoobysrt » Sat Apr 03, 2021 4:20 am
That's an expensive slippery slope for the sake of going to a local garage who has vcds or looking on the vcds thread on this site to see if anyone's local to you.
It could be anything from a leaking hose to a dodgy fuel pump a scan could save you weeks of headaches.
Leeoncupra
Post by Leeoncupra » Sat Apr 03, 2021 6:40 am
Hi matey
I have a carista dongle I use which reads the same faults as vcds can , it can also do coding aswell but it's not picking up any codes atall which leads me to believe its something mechanical thats playing up, if it gave me a code to give me some form of hint I'd be all over it
I will check out the vcds section to see if theres someone local who can do some logs for me for a starting point
Scoobysrt
Post by Scoobysrt » Sat Apr 03, 2021 8:59 am
Sounds like you need the extra features of vcds to pin point it, where are you located out of interest.
Post by Doc » Sat Apr 03, 2021 9:17 am
Checking for fault codes is not data logging.
Get yourself to someone with VCDS and the knowledge to use it properly before you start throwing parts at your engine.
Leeoncupra
Post by Leeoncupra » Sat Apr 03, 2021 9:22 am
Halesowen/stourbridge part of the Midlands
If there is anyone local to here Il be happy to get booked in with them
Thanks gents
