Thursday,01,April,2021,13:53:32:51585
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WV1ZZZ2KZ4X024306 License Plate:
Mileage: 343330km-213335mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZ4X024306 Mileage: 343330km-213335miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 2K0 907 379 B
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00156
VCID: 323D19BB6823F98B497-8066
4 Faults Found:
01276 - ABS Hydraulic Pump (V64)
014 - Defective - Intermittent
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000709938
Coding: 00884F0200041000000000000000000000
Shop #: WSC 35110 377 08192
VCID: 372B28AF83411CA37E9-8062
Subsystem 1 - Part No: 2K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 35110
3 Faults Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit
00987 - Lamp for Brake Light; Left (M9)
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 P HW: 6Q0 909 605 P
Component: 01 AIRBAG VW52 022 2300
Revision: 03022000 Serial number: 0035ED02NFZO
Coding: 0012337
VCID: 44D14F63C297473BEBB-8010
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
VCID: 6FBBD0CFBB919463669-803A
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 2K0 920 940 E
Component: KOMBIINSTRUMENT VDD 3556
Coding: 0000401
Shop #: WSC 00801 210 12153
VCID: 2A0D01DB40F3B14BF17-807E
1 Fault Found:
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001043185540
Coding: 3D0F0140079001
VCID: 270BF8EF53E18C23EE9-8072
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 175
Mileage: 343335 km
Time Indication: 0
Date: 2000.00.00
Time: 02:48:17
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3556
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0130
Coding: 0000000
VCID: 76B5E5ABC4CBA5ABA5F-8022
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.14 1301
Shop #: WSC 00000 000 00000
VCID: 2F3B10CF7B11D463269-807A
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 3320 km
Temperature: 9.0°C
Voltage: 8.40 V
Voltage: 11.80 V
00778 - Steering Angle Sensor (G85)
014 - Defective
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 T
Component: 01 KSG 0560
Coding: 008B0C087F2D84040858010000
VCID: 41DF4677DD855213C0D-8014
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
02483 - Module for Locking of Rear Lid (F327)
008 - Implausible Signal
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75B7E2A7D9CDAEB3AC5-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 J
Component: Radio BNO 0016
Coding: 0020200
VCID: 2D070AC7711DA673145-8078
2 Faults Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
End----(Elapsed Time: 00:47, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
My vcds scan (HELP) with problems
Re: My vcds scan (HELP) with problems
Welcome to the forum.
What are you having problems with? Your ECU can't be found so that's pretty serious unless you know it's powered off or unplugged.
Hi doc i bought the van from a nabour as i seen it lying for well over a year. He said he tried to jump start it about 9month ago and thinks he had done something to the ECU doing it. My rosstech vcds has only 3 vins limited to it and i have got them for my car and 2 family members cars this was just an auto scan that i done on it to try figure out the problem
I've be checking the ECU power supply fuses first up, then maybe check out some wiring.
Buy more vins from rosstech.
Back left bulb is out and the battery wants charging.
But yeah, check the fuse for the ECU.
