Hello people.
It’s that Black ally piece of trim that rises up the door where the window meets the door shut. I had a little accident with a skip so I need to buy a new one but I don’t know what it’s called...
Thank you...
That black thing on the door where the window is
- dan@biali
Re: That black thing on the door where the window is
I had a quick internet search and what I would call it -Exterior B-pillar trim - doesn’t bring up many results! Is yours a Maxi? What year is it? I’ll look up on parts catalogue and see what I find.
#16 on this image
Left side is 2K5 837 889 A 3FZ
Right side is 2K5 837 890 A 3FZ
They should be about £30 each from VW so don't get ripped off on ebay! I believe they are all the same part number for all 2K Caddys but as always, please double check with your parts dept using your chassis number before ordering.
#16 on this image
Hi Dan thanks for the reply, it looks like part 16 on that drawing. Yes I’ve got a maxi 61 plate and it’s the drivers door. I’d just drive the van down to the local dealer but it’s away at the moment and won’t be back for a couple of weeks..
- dan@biali
I would definitely give the dealer a call with your reg number and order through them as I’ve seen some on eBay for £45!
