Hello there, i have just performed the rather simple oil change on my 1.6 Caddy. now it wont start at all. Ignition lights on etc. running perfectly before.
rather urgent, if you know any tips
All oil and etc up to spec
Bazz
W=VW Caddy 1,6 Petrol; wont start after oil change
Re: W=VW Caddy 1,6 Petrol; wont start after oil change
Is it possible you've unplugged some sensor to get to an oil filter?
Just the usual filter and drain plug however when it wouldn't even crank i thought that the oil level and temp sensor might have caused it so i pulled it off and plugged it back in again, that's all i did, no reason i think for it not to even crank. its like the starter motor is not even getting an juice
Do you have any diagnostics computer to check if some fault codes are present?
You have checked all fuses are ok?
Have you over filled it? I'm not certain with a caddy but I know on a couple of other vehicles I've heard of them not starting if over filled.
