Hi has anyone got any photos of where the seat belt is fixed to?
I’ve done the reel and the pillar.
Do I have to drill through the bottom of the wheel arch and put a spreader plate on the outside.
Then bolt from the inside into the plate.
Thanks Dean
Touran seat conversion
Re: Touran seat conversion
I have a maxi so the position is different but you do have to drill through and use a spreader plate. I reclaimed the plates from the donor touran and welded them into my Caddy.
Ok thanks for the reply
Going to do over the weekend
