Not sure if this is in correct topic area
But can someone tell me which model unit this is and if it can run sat nav please
Headunit
Re: Headunit
Apparently it’s called the RCD 330
No it’s not NAV compatible
Best bet would be to get an RCD 340 Apple Car Play and Android Auto
Re: Headunit
I have the exact same head unit & would like to update it also.
Re: Headunit
Can anyone tell me if the Mk3 and Mk4 caddy's stereos have the same outside dimensions (ie can you put a Mk4 stereo in a Mk3).
More from the point of view of space in the dash trim/ screw holes, rather than the wiring.
Re: Headunit
Yes the dimensions are the same MK3 and MK4
Re: Headunit
It’s not a RCD 330 as they have a USB port in the front .
