Headunit
RBJ2206
Headunit
Post by RBJ2206 » Wed Apr 28, 2021 9:07 pm
Not sure if this is in correct topic area
But can someone tell me which model unit this is and if it can run sat nav please
Russ74
Re: Headunit
Post by Russ74 » Sat May 01, 2021 9:21 am
Apparently it’s called the RCD 330
No it’s not NAV compatible
Best bet would be to get an RCD 340 Apple Car Play and Android Auto
Fat Eric
Re: Headunit
Post by Fat Eric » Sat May 01, 2021 1:35 pm
I have the exact same head unit & would like to update it also.
lscott141
Re: Headunit
Post by lscott141 » Sat May 01, 2021 2:02 pm
Can anyone tell me if the Mk3 and Mk4 caddy's stereos have the same outside dimensions (ie can you put a Mk4 stereo in a Mk3).
More from the point of view of space in the dash trim/ screw holes, rather than the wiring.
Russ74
Re: Headunit
Post by Russ74 » Sat May 01, 2021 4:53 pm
Yes the dimensions are the same MK3 and MK4
RBJ2206
Re: Headunit
Post by RBJ2206 » Sat May 01, 2021 6:08 pm
It’s not a RCD 330 as they have a USB port in the front .
