warning light and supposed belt change
carsounds_dan
Post by carsounds_dan »
Hi
I picked up the caddy finally yesterday from the dealers... and drove 200 miles home.
On the way home a warning light came up and then went off (after 3 minutes). It was a little yellow/orange light showing a steering wheel, which was on solidly.
I also brought the van under the pretense that it would have had a cambelt change, I didn't check this out fully at the dealers as it was hammering down and I was getting annoyed, today after it's done 250-300 miles since this change I unclipped the top belt cover and had a look and the belt didn't strike me as being "new". It still has very noticable VW signs on it and text but has a some what brown discolouration to it. The van is on 80000 miles and I just wondered if this sounds alright or should I be banging on their door?
Many Thanks
Daniel
7555doctor
The only Caddy in the Village
Re: warning light and supposed belt change
Post by 7555doctor »
i have the same light on to but my light came on when i had the streeing wheel off when doning the cruise control.
do nt think it is timing belt could be worng.
NEED A CADDY AGAIN WISH I HAD NEVER SOLD MY VAN
The caddy2k.com drifter
hedge
Post by hedge »
try this
Center steering wheel (±10°) and hold it centered for 5 seconds.
Turn steering wheel completely to the left and hold it there for a second.
Turn steering wheel completely to the right and hold it there for a second.
Center steering wheel (±10°).
Switch OFF engine and ignition.
Switch ON ignition.
Wait 5 seconds.
Steering Assist Warning Lamp should turn OFF. If it doesn't, perform a short test drive.
or vagcom if you have it
carsounds_dan
o the light came on and went off by itself.
the light is red when you first put the key in (all lights alight) and then goes out.. but at the time that it was lit it was yellow/amber..
The timing belt is not related I hope, I was only asking opinion on the matter, sorry for any confusion.
7555doctor
my van does the same thing lads goes amber then red.
hedge just got my vag lead today may need help to get this fixed if your free
doc run a test with vag com and nothing was coming up for this problem and the
doc is on his hoildays with the woman
my P.A.S is very heavy this only happened when i put the cruise control in the van
and the light came on when i do nt disconent the battery.
steering be came very heavy when i put the touran steering control module in the van.
maybe the module is the problem i do nt know yet.....
7555doctor
just got my lights off there now with vagcom
now i have power steering again.
Done the basic settings for the steering angle sensor:
http://wiki.ross-tech.com/index.php/VW_ ... Adaptation" onclick="window.open(this.href);return false;
