Can mk4 stop/start be coded out
Hey everyone, i tried coding out the stop/start (cylinder deactivation) on a mk4 1.4tsi and I my rear view camera stopped working and it seemed to allow the engine to switch off still, I was OBDeleven and it’s shows it should be able to be done in central electrics long coding but it must need some other parameters changed too, I changed it back and camera came back straight away so seems weird, thoughts?
- caddychris2002
Re: Can mk4 stop/start be coded out
You can reverse the action so it starts off and pressing the button turns it on.
IIRC. go to 09-Central Electrics > Security Access > type there: 20113 then go to Adaptation > Channel 34 > and change value to 0 (New Value) after that just press TEST button and after SAVE.
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
Mods:
Thanks mate, I’ll be happy with it being reversed, When I tested the start/stop deactivation using the OBDeleven I noticed that if the drivers seat belt isn’t plugged in the engine won’t turn off, and I thought it was working, then I realised once I put the seatbelt on that it still turns off.
I’ll give your method a go and let you know if it works on my van
Hey Chris
I managed to get in with security codes that are on OBDeleven, but when I go to adaptions then into channel 34 it wont let me add a new value, ill try to attach a screen shot.
