Odd one with the heaters this morning
Not Normal Dan
Post by Not Normal Dan » Sat May 01, 2021 6:20 am
Bit of an odd one this morning really, so set off for work and set the heaters to windscreen.
Anyway after a while I changed the position to footwell but it still stayed on the windscreen position no matter where I put it.
I turned it on and off and eventually it all seemed to be operating as normal, never done it before and tried it a couple of times since getting to work and it’s fine now.
Vans a 65 plate mk4
NZDubNurd
Re: Odd one with the heaters this morning
Post by NZDubNurd » Sun May 02, 2021 12:18 am
You may need to do a flap re-alignment.
You can do it with VCDS, but also from the climate control panel - On my 2006 with climatronic, you hold the ECON button then press the FEET button (I think that's the combination). Google should have details though.
Occasionally the motors have a hissyfit or stick etc and once the control unit logs a code, it'll sometimes not try to move that motor again.
