Different dash.
Different dash.
So I have a 2005 caddy. What are my options dash wise. When I had a company van a few years ago i really liked that and that was a mk4 caddy. What are my options and pictures would help.
Vw caddy under modification.
2 old audi’s still under construction
If it’s not modified it soon will be.
oem gud but modified is even better
- Cabbs
Re: Different dash.
I do believe the MK4 caddy will fit but it’s really hard work and not straight forward. I’ve just fitted the Touran dash which is a straight fit and easy to do. You also gain a glovebox as opposed to the cheap plastic one you can buy which always breaks.
Re: Different dash.
I do like that style to be fair. What clocks did you use. And what age did the dash come from. I’m still lurking in the caddy front
- Cabbs
Re: Different dash.
[mention]flat out 90 [/mention]
The dash came from a 2009 although the chrome
Vents came from a MK2 which was 2013 I think.
The cluster is a Touran premium colour one.
Added the top dash compartment today because when using the Mk2 vent housing the Mk1 compartment doesn’t fit.
Re: Different dash.
This looks wicked cabbs, is this a straight forward job? I don’t like the idea of playing around with the airbags ect. Would love to do this as a future project! Also I’m not sure how to tag people so not sure if you’ll see this lol
- Cabbs
Re: Different dash.
[mention]Jordan morgan [/mention]
Easy mate. There not much to a caddy dash. There’s a video on You tube too by Dan Chambers. Go
Watch it mate. As long as you get everything you need you’ll be fine including brackets and the vent ducts at the back. It’s cost me just over £100 for everything mate. Remove your earth on the battery before disconnecting the airbag and it won’t give you an error light.
Re: Different dash.
I think this will be the route I go down then Iv just need to look at swapping the clocks over then. Thank you for all your advice I know witch route to go down.
[ quote=Cabbs post_id=398083 time=1620157560 user_id=18877]
[/quote]
[/quote]
Re: Different dash.
Sorry to reignite this post
Has anyone or can anyone change the mi4 caddy dash?
I absolutely love the caddy but HATE where the satnav is positioned
Someone suggested it could be swapped out with the mk6 golf but I am not that tech savvie to do myself
If anyone can do this and up for it I’m happy to pay
