Hub caps
Hub caps
I got a set of second hand hub caps for free for my caddy but the centres are a bit perished and 1 is missing the centre. I can't find anything on the Internet regards replacement centres, any help much appreciated. [5K0071455]
Sent from my SM-G781B using Tapatalk
- dan@biali
Re: Hub caps
On parts diagram there is no mention of individual parts, just the hubcap as a whole piece at about £88 a set or £26 each (which is £104 for 4 ).
Re: Hub caps
Yeah, I was hoping to do it on the cheap but might just have to shell out for new ones, thanks pal
Re: Hub caps
There are lots of VW logo discs of many sizes on AliX
One might work ?
One might work ?
Re: Hub caps
Just buy a set of centres off ebay. Make sure the centres are stuck down securely before driving though, I lost a few that didn't stick too well!
Re: Hub caps
I bought stick on ones from eBay to cover my audi centre caps. Nearly 4 years later, they’re still on. They weren’t very expensive, about £10/15
- Ripley55
Hub caps
Thinking I may have to go down that route as well Pete
Picked up my Audi wheels yesterday and the centre caps are obviously OEM (8W0 601 170) 60mm. So unless anyone on here has found decent VW ones to replace them ? It’s looking like stickers ? OEM Audi ones have the 4rings, and they are removable with 4 little tabs (photos below) Any ideas chaps ?
Re: Hub caps
Have a look here.Theres also a how to measure somewhere. https://www.rhinotuning.com/ I got these wolfsberg design for mine They come complete . Good quality .Time will tell https://www.rhinotuning.com/products/vw ... -3b7601171
Re: Hub caps
They look similar to mine. I did the same, just popped out the Audi rings.
- Ripley55
Re: Hub caps
Got two sets from Rhinotuning, and neither fit !! they weren't dear, but hey ho, you live and learn
I think I'll do what you did Pete, and go for some 60mm domed sticky on ones
Re: Hub caps
It’ll save you a headache mate
Re: Hub caps
Looks like when you remove the Audi rings the VW stickers may not have anything to stick to. The stickers I bought (Skoda) were slightly domed. However you could always epoxy them on - just make sure they are fully dry before you go for a spin.
