2011 Ex BG 1.6TDI Caddy not cranking over
I've just bought a damage repairable 2011 ex BG caddy as a cheap camper project. The van came without a battery (yup complete madness I know because that could hide all manner of issues) tried my normal MK2 Golf battery on it. Lights on the dash with the battery light flickering engine not cranking. The battery isolator has been bypassed still no joy. I'll get the correct battery because it has stop start, but expected it to at least crank over. Could it be an imobiliser fault or would I still expect it to turn over?
I have'nt got an OBD reader, not sure if that would be any use at this stage?
Re: 2011 Ex BG 1.6TDI Caddy not cranking over
The immobiliser will block the engine running, it will still allow the engine to to start but not run.
- AlwynMike
Personally, I wouldn't bother going to the expense of a Stop Start battery. A normal battery is fine, just the S/S may not operate.
Unless of course you really want the Stop Start!!
Are you sure it has stop start?
I've not come across an ex BG with it.....but I could be wrong.
Well with the key in the ignition and switched on the lcd display says "depress clutch". That is how our Skoda Citigo stop/start works. But I could also be wrong!
Are you saying that depressing the clutch is just a safety feature on more modern VAG vehicles? - our other car is an 08 Skoda Scout so pre stop/start depress clutch malarky!
Apparently an imobiliser fault shouldn't stop it cranking which aligns with how my old-skool laserline imobiliser works.
So based on some feedback re-checking the battery leads and check/swapping the ignition switch seem to be the first easy fixes. I suspect the clutch connector may be working based upon the fact the "depress clutch" message disapears.
My 2011 ex Brit gas one does the same (depress clutch). As far as I’m aware it’s on nearly every single VAG car from 2009. That’s just literally put your foot on the clutch to start it. (Safety feature)
OK. It appears I am wrong about the "depress clutch" only ever come across stop start on our Citigo and a Kia hire car! Thanks for putting me straight!
So I'll recheck the battery connections and check/replace the ignition switch.
So this weekend I tried some easy fixes.
A replacement Ignition switch came next day when ordered from B&B off ebay, great service and price as ever. Rather than commit to removing the old one I just disconnected it and plugged in the new one. So Key in the ignition and screwdriver dialling round the new ignition switch, no change in symptoms. All lights on the dash and the battery light flashing.
I've also connected the battery live feed directly back to the fuse box missing out the immobiliser, however the immobiliser cables are still connected. Do i need to do anything about them? - assume not.
I also bought a Streetwise OBDII reader from ECP just to see what came up.
Getting code P0671 - Cylinder 1 Glow Plug issue as well as well as 2 x P06?? errors, but nothing else. Having a read thro on the T'internet seems to indicate that this probably isn't causing the no crank issue.
Any advice welcome.
Any advice welcome.
How is the battery voltage?
To me, because of the flashing battery light, I'm thinking something voltage related.
Thanks doc. I'm using my puny MK2 Golf battery which works fine on my 1.8 Gti so that might not be man enough. Hopefully we'll get the new battery tomorrow.
If the immobiliser circuit is still being used the key needs to be next to the pick up ring around the ignition or it won't pick the chip up, some can be very temperamental on placement.
If the battery light is flashing I suggest the problem is in that area. Did you say you've bypassed the inertia switch?
- Cabbs
Sounds like an immobiliser issue to me.
You really could do with it plugging into vcds and firstly clearing all the error codes and go from there.
I've not been been to bed yet so my mind is a bit hazy but I'm pretty sure the engine still cranks if it's an immobiliser issue, it just doest fire or it does until the fuel in the lines is used up. Again lack of sleep may mean I'm wrong but an immobiliser issue brings a light up on the dash I think.
As I mentioned earlier, I am under the impression all modern vehicles should have an inertia switch incase of an accident, I don't know for sure if the caddy has one or where it is but its something to look into.
Plugging into vcds is certainly the right shout imho.
Auto electrician came today and cleared all the codes. He seemed to think there maybe a dodgy battery to engine earth as previously indicated. Only outstanding code relates to the fact the drivers headlight isn't connected 'cos it got smashed. Cost a little more than I expected but we can now move forward and sort the bodywork.
RESULT!
RESULT!
So it now starts and runs?
