Does anyone know for sure if all swb side loading doors are the same from 2004 to 2012...? Seem to have close part numbers
2004- 2k5 843 107a
2012- 2k0 845 107r
Side door swap
- Giddy
Re: Side door swap
Would be easier if you clarify what you after? Life or panel van door, left or right side?
2k0845107r is not a valid part number, 2k0843107r maybe? It looks as though one is for life, the other is for panel van.
Re: Side door swap
Ah, I have a Sbw 2012 panel van and need a direct replacement panel van side door, just wanted to know if all Sbw panel van doors are the same, I probably shouldn’t have confused things with a googled part no
- Giddy
Re: Side door swap
I believe the door itself is the same, but the wiring is slightly different for a pre-facelift Caddy door. You can swap over everything, but maybe getting the door from a right generation Caddy would be easier.
Re: Side door swap
Thanks bud, that’s good advice....
