Fog lamp wiring order mistake!!
Just ordered a wiring harness from eBay but clicked the wrong option The seller lists loads of different variations in separate ads, I clicked T5/ Caravelle rather than T5 /Caddy. The seller when contacted has said simply decline delivery and it will be returned to them for refund .My question is that since all I am actually buying is a length of wire , relay , fuses and plugs will it still fit. The seller didn’t answer that question as I guess they simply resell items Are T5/Caravelle spots the same plug as Caddy’s ?
Re: Fog lamp wiring order mistake!!
For info: arrived today will fit no problem just need to solder & crimp on a terminal for the switch plug and if being picky swap out the fog light plugs - they fit Ok but the locking tabs are 90 degrees out.
