SD slot
GeeTee10
Re: SD slot
Post by GeeTee10 »
sorted
card out. I sort of thought this is what was happening. As you can see the clip cover is now in two parts. But, basically there were two sprung tabs on each side meaning the cover can be push in ok, but not be pulled out. I had to get some cable cutters on it as it made from thin metal. Simple cut up the spine length and it came out.
Then took me about 5 hours of downloading and failed update attempts to finally update the map. But that's another story. lol
Thanks for the help
Reason: changed to a full size picture link
Re: SD slot
Well done
Must be a device to stop driver from removing or changing (losing) the SD card.
Scoobysrt
Re: SD slot
Post by Scoobysrt »
Sorry I missed your updates, there is a way to get these out but I guess you've found your own way lol,
Re: SD slot
Tease !
How do you do it then ?
:popcorn:
Scoobysrt
Re: SD slot
Post by Scoobysrt »
Sorry my bad, the tool is very much like the aforementioned feeler gauge but it has a notch cut out, there are 2 of them to pull the tabs back in and pull the blocker out.
I think I know where mine are so ill find them out and take a pic and dimension them for you.
Re: SD slot
Thanks Scoob
Scoobysrt
Re: SD slot
Post by Scoobysrt »
No problem mate, can't just lay my hand on the tools, they aren't were I thought they were, they were part of a kit and I've lost the full thing at the moment :roll:
I'm moving house so will turn up at some point.
Re: SD slot
I am constantly losing things these days, mostly turn up just after I buy some more - Doh !
Scoobysrt
Re: SD slot
Post by Scoobysrt »
Lol ain't that the truth hence I've a box full of stereo removal tools lol.
cactusgreen
Re: SD slot
Post by cactusgreen »
@GeeTee10
So what version you now running....I've been trying to get an answer out of vw as to what version is now stable and not killing the units.......
Rear ended and killed :cry: 1.9 TDi DSG indian blue wrapped in slightly darker blue lol, now replaced with a new Highline 1.6 TDi DSG bit naked without the logos yet - rather fun but not quite my Audi S4, but makes me smile as much as my 2.6e 80 Cabriolet!!
