Hi
I've used the search as much as I can, as new member I can't see an awful lot.
It's an 06 2.0 sdi.
I've an oil leak at the back of the engine somewhere, quite high up. Any ideas where the most common place is for it to leak? I've got a large jack but no access to a ramp.
I've replaced the steering angle sensor, all that is fine, and did it with the battery disconnected but the airbag light is on. Will a normal eml reset work or will it need a fancy thing or vcds to remove?
I need to fit a tow bar. What would be better, a dedicated kit or would a bypass relay be sufficient? Oh, it'll be connected to a trailer with led lights so presume dedicated but not used to caddy's.
That's it for now. Just wanna get it on the road and mot'd, then I'll do a couple of little mods.
David
A couple of small problems
Re: A couple of small problems
The oil leak could be from the tandem pum if the seals ar old, in my case the gearbox was covered with oil, and with the airbag light you will need Vcds to reset the error, in the worst case scenario you will have to recheck the wiring connections.
