Hi guys,
I've a 2011 1.6 caddy with fault code P0087.
So far changed the below
HPFP
LPFP
Fuel filter
Pressure sensor Fuel line
Fuel filter housing replaced
Checked no kinks in Fuel lines
Injectors Checked and fine.
Any ideas van is perfect until it you drive it a few mins then it goes into limp mode.
Seanick
Caddy P0087 fault
Re: Caddy P0087 fault
Did you get any live measurement readings from the fuel pressure sensor? I'm thinking there might be a wiring problem somewhere between the engine bay fuse panel, the ECU and the sensor.
Hi m8,
Thanks for the reply.
No it was just a generic reader the lad had.... would this req vag com?
Seanick
Seanick
VCDS is your best bet for live logging.
Hi m8,
I haven't been able to get anyone with vcds to look at it but had some live measurements taken with a sanp on elous reader.
It was showing fuel pressure rising until limp came in then a drop off but if you continue driving the pressure will rise again up to 80-90000(kpa).....idle was around 23(kpa) I think.
I have identified the wires from the ecu to the 3 pin switch in the fuel rail and ran another to eliminate although the belled out ok.... still the same issues.
Still the 2 codes P0087 and
Will try to do the same with the other switch
@doc was this the live measurement you were referring to? (Fuel pressure)
Seanick
Seanick
With VCDS, you should be able to log the requested fuel pressure Vs the actual, that will let you see if there's something happening and when.
