Possible power upgrade
Regan77
Post by Regan77 »
Hi, I’ve just bought a 2013 1.6d maxi caddy that has had a wheelchair access conversion. As you can imagine with all this extra weight they car is a bit sluggish. Has anyone had a chip or something else done to up the power and if so what was the difference. Sorry I’m a complete mechanical noob with cars.
Regards Steve
Gazear
Re: Possible power upgrade
Post by Gazear »
Get a remap on it. And you’ll see the difference
2012 LWB 1.6 101 blue. Not a BG van.
Jono1
Post by Jono1 »
@regan77
A remap will defiantly make a difference if your just after a bit more power.
Where are you located? I’m sure someone can recommend places to go and get a decent remap local to you .
DjLoop
Post by DjLoop »
I would say start with remap and if that is not enaugh go for DPF delete and EGR delete and then remap agin. After that is done it starts to be exspensive
Vw Caddy 2008 Carrera Cup Showcar/Db Drag/Demo car
1200Ah Winston Lifepo4 Lithium
114kw in Amplifier power
140m 40 x 40 Steel reinforcement
Bullet Proof Glass "14mm"
370a Mechman Alternator
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
038 130 073AL injectors
Turbo GTB1749V
Full Powerflex
Regan77
Post by Regan77 »
Thanks guys I’m in the north east. I’ll do some research on a remap cheers for the help.
Jono1
Post by Jono1 »
Dyno remaps in Middlesbrough?
I’m northeast too, I haven’t personally used them but know a few people who have and they have all been positive reviews.
