The coilovers vs springs
Well everyone looking for some caddy vets to help me out looking to lower my van , I have bought 45mm eibach springs . But people are saying to me coilovers are better for comfort , I’m sure this question has been asked and answered but would love to know your opinions.
Thank you
Thank you
- Bad666
Re: The coilovers vs springs
I’m looking as well T I’m looking at Bilstein or darkside bc racing? Would be interesting to see what people think.
If 45mm drop is all you want, so long as your original shocks are in good condition, you won't go wrong with Eibach springs.
Why someone would suggest coilovers to be a better option for such a small drop is beyond me.
I don't see how comfort changes, I've had vehicles lowered on springs and vehicles lowered on shocks and springs, the spring is the deciding factor I think as long as your original shocks are in good order I don't see a difference but I haven't done both options on the same vehicle so can't say for sure.
What I will say it lowering on adjustable shocks allows you to set the ride height correctly between front and rear if dropping a decent amount. With very reasonable kits available under £400 for front and rear together I think its a no brainer to do the shocks as well.
Edit, doc beat me to it lol.
Great replies all round thanks very much !
- Limzy2k
@Bad666
I got a set of B4’s & eibach springs as a kit, will be fitting them soon got to do timing kit & water pump tomorrow after work I’ll let you know how they ride once I’ve got them hooked up
You can buy 'cheap' coilover sets, which ride horribly as they are made to a budget.
If you wanted to lower it by a set amount, as Doc says, springs are all you need and if you want to drop it further then you ideally need a decent set of coilovers, but you will need to spend out on a good set if you don't want a shite ride.
I'm doing my shocks, spring and brakes this weekend. I have opted for new Bilstein shocks with H&R springs up front. Then flipping the rear axel with a Darkside kit. I'm only looking for around a 50/60mm drop overall.
The 'cheap' coil over sets get quite good write ups on here perhaps there's even cheaper ones then often mentioned.
- Bad666
@Limzy2k
Let me know
Let me know
Reason: removed quote, added username tag
- Limzy2k
@Bad666
How’s it going mate got it all dialled in now! Rides real nice now deffo deffo recommend!
Did take a little longer than planed had a pressure fit nut on the top hat spin loose that I had to drill out. And I ended up doing CVJ’s while it was all off.
The back was a bit tricky, drop the rear axle, flip the leafs there’s locator pins you need to remember to flip them too, couple of pains but was a fun job!
- Handyandy
If you watch the wolfsburg channel on YouTube they use the eibach springs from darkside they reckon there far more superior than coilovers
I bought a budget set of coilovers and I do get a harsh ride I'm thinking of changing to the eibach lowering springs
- Limzy2k
Yeah man honestly I couldn’t agree more, all my other cars on on coilovers… I’m glad I put the caddy on the B4 & Eibach combo. Really happy with it
- Bad666
What kits did you use in the end Limzy2k ?
- Limzy2k
Went for:
Bilstein B4 shocks front & rear
Eibach springs 60mm
Adjustable shackles
Brought that all in a kit for £449 3days posted
Went for MOOG drop links all corners roughly
£14 a corner
Eibach springs 60mm
Adjustable shackles
£14 a corner
Hi mate where did you get the kit from please?
More to follow
More to follow
