Sliding door lock problem
MikerBike
Post by MikerBike » Wed Jun 30, 2021 8:21 pm
Hi all, looking for a bit of help.
Caddy Maxi 1.6tdi 2012.
When locking the doors from inside with the button on the drivers door, the drivers side sliding door locks but then unlocks again. If I press the button on the sliding door down and hold it for a couple of seconds it will stay locked.
Locks ok with keyfob when outside vehicle.
Any ideas?
2012 Caddy Maxi 1.6TDi 102bhp
Scoobysrt
Re: Sliding door lock problem
Post by Scoobysrt » Thu Jul 01, 2021 8:23 am
Are the other doors shut whilst your trying this?
Clean the contacts and see if that helps.
MikerBike
Post by MikerBike » Thu Jul 01, 2021 10:04 pm
Yeah all the doors are shut. I’ll try cleaning the contacts - thanks.
ARSHAADJ
Post by ARSHAADJ » Sat Jul 10, 2021 6:03 am
I'm having the same issue.
MikerBike
Post by MikerBike » Thu Jul 15, 2021 6:13 am
I cleaned up the contacts but that made no difference so took the door card off but couldn’t see anything really. Ended up taking it to a local independent specialist who determined that the lock was knackered and replaced it. Solved the problem with pound notes!
