retrofit cruise control
Hi there guys. I am new to this forum. My name is Mike....and I am from Swansea. I have recently bought a 2013 Mk3 Caddy maxi 1.6 (102) tdi auto model. I would like to fit cruise control is this easy? is it something I can do myself?
- C Chis
Re: retrofit cruise control
Hi Mike!
Welcome to the forum.
Retrofitting CC is fairly straight forward. There is a good how to in the technical section that shows you how. You'll need to get your post count up and then request access to the tech section.
Good way to get your post count up is to start a build thread for your van and get some as is pictures posted up...
Thanks for the reply, not to good at this posting thing computers not my best skill too old to learn. I will see what i can do
- Papa Bear
Also put where you are from and someone local may be able to help you out.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
I’ve got the same year and engine as you, I’m looking at fitting cruise control as well! Have you managed to sort anything yet?
Could do with cruise control myself... Let us know how you get on
- Papa Bear
Fitted to ours, followed the how to guide to get the right stalks. Just needed coding and all worked first time
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
@ Papa Bear
What's involved with the 'coding'?
Sorry, I'm a bit green with car stuff
- Papa Bear
Need VCDS or similar. I used it as an excuse to purchase it, used it for much more since.
There may be someone local with it to help you out.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Have found a mobile fitter who will supply everything and recode it based in south wales so reasonably local for me.
Hi Mike,
can I ask how much will it cost?
Heard on some its not just straight forward just adding stalks think u need the module too ?
Most modules from 2010 onwards support cruise control even if the stalk is not there from factory.
Buying new parts, it can get expensive, I think £120 for stalks plus fitting and coding.
The stalks can be picked up used for £30 or often less.
What a bargain! Need to get this sorted!
Doc will a touran cruise control stalk fit from a 04
On a caddy 2014
On a caddy 2014
