TPMS sensors
TPMS sensors
HI all
Looking at purchasing some new rims. I have a 19 reg maxi 150 dsg. I take it has tpms sensor, if so what ones do i need to order, i would rather not take them out of the old rims.
Re: TPMS sensors
It's probably best to speak to VW parts about ordering a set the same as is on your caddy. There's different frequencies and specs so just stick to what you know works.
It'll cost you more in the long run if you get the wrong one and have to change them.
Re: TPMS sensors
Sound like a plan. Thanks
Reason: removed quote
Re: TPMS sensors
My 18 reg has TPMS, but no sensors. It is all done by the wheel speed sensors and ASR/ABS type stuff ?!?! Apparently.
- anoneamus
Re: TPMS sensors
This is "virtual TPMS" or TPMS2. It's not as good as real TPMS (it can't actually measure pressure), but works pretty well (it's caught air leaks for me).
Re: TPMS sensors
Oh Ok, So possibly no physical sensor. How would one find out?, other than to remove a tyre.
Re: TPMS sensors
Do you have tyre pressure menu with live readings on your instrument cluster?
- anoneamus
Re: TPMS sensors
The reason for asking is, i thought all vehicle after 2014 had to use tpms and not abs and wheel speed sensors. I want to change the wheels and was worried i would get a fault. On the display i have the options under tyre monitor to store the pressure. (not as a value just that all pressure are correct).
If my caddy used abs/wheel speed sensor then all is good.
Re: TPMS sensors
If you're saving pressures by setting them and then having the vehicle learn it, you've got the indirect TPMS with uses wheel speed sensors to determine diameter and therefore pressure loss.
The system with sensors in the wheels will give you a live pressure readout per corner.
- anoneamus
