6 Speed swap and now ECU wont accept 6 speed coding :(
gavzzorz
Post by gavzzorz »
Hi all,
Iv just fitted an 02Q gearbox and all related to my 1.9tdi caddy, all fine and working but gone to do the VCDS coding to put a number 2 in place of the 1 to say its fitted with a 6 speed and says Error 31: Request out of range.
im guess in the ECU i have doesnt support a 6 speed :(
does anyone know of a way around this or know of an ECU Part number that does support the 6 speed and is for a 1.9 BLS caddy EDC16u34?
its annoying because iv done all the tuning for this caddy and now it doesnt work with the 6 speed.
cheers :)
55 Caddy 1.9tdi ASZ - Refrofitted Cruse, Projectors, HID, Auto Wipers, Auto Lights, Footwell Lights, Highline Display, MFSW, AL Injectors, GTB1752 turbo and 02Q 6 Speed.
zu11y
Re: 6 Speed swap and now ECU wont accept 6 speed coding :(
Post by zu11y »
EDC16u34 wont allow coding to 6 speed via vcds. either needs a file from a ecu with 6 speed factory or modification to the original ecu file
or you could get a ecu from car with factory 6 speed and code to the van
2006 black caddy, 2.0 BKD converted, custom leather seats
fully qualified auto electrician always willing to help
I had a EDC16 ECU work perfectly with 6 speed, the earlier Caddy 1.9TDI ECU could handle it no problem.
If you get an ECU from a six speed Golf of Touran with a BLS, it's straightforward to adapt the immobiliser. You will need to have some emissions control removed via a remap as those cars had things the caddy didn't.
gavzzorz
Post by gavzzorz »
Thanks for the replies guys, feel stupid as i should have just checked it really...
So i got the swap all sorted yesterday and tried to change it in the ECU as i thought you had to, when i got the error 31 i thought the ECU didnt support the change even though i know it has the Injection Duration and SOI maps to support the 6th gear.
I made a map last night with a change i found within the map but before flashing that on i went for the first test drive and it just works...
so for future reference if anyone is doing a 6 speed swap and you have an ECU model/SW 03G906021AQ the Cruse control in 6th just works :)
Russ74
Re: 6 Speed swap and now ECU wont accept 6 speed coding [emoji20]
Post by Russ74 »
I’ve done a 6speed on my 2014 caddy 2.0tdi and it also doesn’t show on the cluster and the cruise doesn’t work in 6th.
gavzzorz
Post by gavzzorz »
you got VCDS? tried to change the coding within the ECU?
Russ74
Post by Russ74 »
I have it goes back to 5 speed
gavzzorz
Post by gavzzorz »
you need to do what zu11y/Doc mentioned then, either needs...
- ECU file adjusting by yourself or someone with WINOLS and a way of pulling the MAP with a tool like MPPS/KESSv2.
- ECU from a 6 speed car with the same engine.
i was going down the route of editing my MAP as i have the tools and have been doing so anyway.
Russ74
Post by Russ74 »
Awesome thank you
So I can use a 2014 touran or Tiguan manual with 2.0 tdi Ecu
gavzzorz
Post by gavzzorz »
yeh yeh exactly or even other models with the same engine like a Golf. do you know what your ECU model is?
Russ74
Post by Russ74 »
Let me have a look when I get home.
I’ll plug in VCDS and report back
Russ74
Post by Russ74 »
Here it is
