What mods first?
Ryanmw90
What mods first?
Post by Ryanmw90 »
So I have a 1.9tdi lowline and have a spare £300 to spend on it. Recently put a midline control module in and cruise control stalks.
So the question is if you had £300 what would you spend it on?
New dash?
Cluster?
Steering wheel?
Remap?
Seats?
Stereo?
Just can't decide 😂
Scoobysrt
Re: What mods first?
Post by Scoobysrt »
If its not been mapped out of your list I would say go for that, the difference is night and day.
Ryanmw90
Post by Ryanmw90 »
Definitely going to look into it, wonder what kind of gains it will get!
Oldgregg
Post by Oldgregg »
You’ll probably end up with around 140hp depending on dyno. It depends what you already have but I got touran door cards, armrest, front bumper, carpet, seat bases and seats for £50 from a locals scrapy. Or if you already have the seat bases you could get a nice pair of seats for £300.
The remap does make a big difference but it also depends how mechanically sound your vehicle is. You could end up needing a new clutch or turbo before you thought you would.
Scoobysrt
Post by Scoobysrt »
1.9 you could go 180 ish with no problems.
Drewcole
Post by Drewcole »
100% a remap, made mine a hell of alot more drivable.
Also, the 1.9 can get clogged up if it hasn't been well serviced, remover the egr prior to mapping (so it can mapped out), or give it a bloody good clean.
Also, get some Cataclean through it then some good fuel, it makes a difference.
Ryanmw90
Post by Ryanmw90 »
@Oldgregg
Definitely be going down the breakers and see if they have anything I can use! Haven't got a clue how good the engine is tbh 😂 never really worked on engines before.
@Drewcole
Whats the benefit of removing the egr? Is it a easy enough job? Isn't it a MOT failure? Or is there ways around that
Reason: removed unnecessary quotes and combined two posts in one reply
Drewcole
Post by Drewcole »
The EGR returns quite a lot of the exhaust gasses back through the system and cloggs it all up which basically goes towards strangling the engines performance over time.
Removing them makes it perform better and will aid it being more responsive.
Just removing it will throw up a light on the dash, but you can map out the EGR, so if you are going to have it tunned speak to the tuner first to see if they can do it, then remove it prior to going for the map and then you won't have a light come up.
Won't fail the MOT as long as the rest of the engine is running well and isn't chucking out a load of crud from the back, decent service and good fuel will see the engine run at its best.
X5PEA
Post by X5PEA »
@Oldgregg Are Touran door cards a straight fit?
What vehicle is the arm rest out of mate?
Caddy-alby
Post by Caddy-alby »
go the whole hog straight out the gate.
Cheap coilovers for now.
Wheels a must
remap
touran dash with aircon
Touran carpet and seats to finnish it off
After that just add bits as and when you have the time
2007 Caddy, ASZ, GTB1756VK, all the good stuff to make it work
Oldgregg
What mods first?
Post by Oldgregg »
[mention]X5PEA [/mention] All the parts I mentioned were from a Touran. The door cards need a slight modification, just a bit cut out. What year is your caddy?
Millencolin
Post by Millencolin »
Anyone else have any fears re maping ecu.
I have 2.0 tdi and only 76kw and man i miss my 103kw jetta…
Been on and off mapping since i bought the car.
Golf mk4 1.6l 2002 (Sold)
Transporter T4 2.5Tdi 2001 (Sold)
Jetta 2.0Tdi 2010 (Sold)
Passat CC 2010 2.0Tdi
Caddy 2.0Tdi 2017
Drewcole
Post by Drewcole »
Mapping isn't really going to stress things anymore unless you push the limits on it.
Generally you'd be driving a lower powered car hard most of the time to get to speed, a good map by someone who takes into account the age/mileage/wear etc will leave you with something that doesn't need to be driven as hard.
Yes, if you just have the limits maxed out by someone who doesn't really know what they're doing and then thrash it, it will break.
