Caddy Maxi MPG
Mike Retallick
Caddy Maxi MPG
Post by Mike Retallick »
Got this caddy Maxi only done 23K on a 13 plate, what sort of MPG can I expect?
Re: Caddy Maxi MPG
Different engines get different MPG, which engine is in yours?
Mike Retallick
Re: Caddy Maxi MPG
1.6 D with auto box
Re: Caddy Maxi MPG
My SWB 1.6 with manual gearbox did 600 miles to a 60 litre fill of fuel so that equates to 45MPG (UK).
DSG uses a bit more fuel but not very much, I'd expect 42-43MPG if I were doing the same trips with DSG. Maxi being a bit bigger than SWB, you might be just slightly less.
totty79
Re: Caddy Maxi MPG
Post by totty79 »
Mins also a 1.6TDI DSG Maxi (Kombi), I get 38mpg
Wafflepug4
Re: Caddy Maxi MPG
Post by Wafflepug4 »
Mines a 1.6 TDI maxi and I get 100 miles from 10 litres.
I've noticed each notch on the fuel gauge is around 35miles - I use it as a pretty good estimate to work out as to how many miles I have left in the tank if I'm going on a trip etc
naylar
Engine size/power: 2.0 CNG (107bhp)
Re: Caddy Maxi MPG
Post by naylar »
45ish all round in a 2.0L Maxi here and that's with BFG tyres on.
Mike Retallick
Re: Caddy Maxi MPG
Thanks for the replies guys, its showing 32mpg at the moment but only been doing short hops about town. will have to do a long run to see what it will achieve
totty79
Re: Caddy Maxi MPG
Post by totty79 »
Mine has been known to drop to 34 if only doing short runs so you're not far off.
