2007 caddy rear axel
Posted: Fri Jul 16, 2021 11:36 am
by Bigcheese
Hi there I’m new here and am after abit of help and advice I have a 2007 Vw caddy I have had it for around a year now and have recently found out that some body really bodged the rear axel when lowering it so I now need another rear axel I have hear that most axels from a caddy will fit but I just really wanted to confirm this is true before I buy one any help would be greatly appreciated.
Thanks lee
Re: 2007 caddy rear axel
Posted: Fri Jul 16, 2021 12:57 pm
by Doc
Not all axles are the same.
The SWB van had 3 versions, the maxi I believe had the same.
There are different widths, shapes and hub fixings.
You can fit a different one and make it work without any modifications. That said, you may run into problems if you've got big wheels or run really low if you end up fitting a different axle.
Posted: Sat Jul 17, 2021 12:17 am
by Bigcheese
I have 18” Audi rotor alloy wheels on it at the moment so I’m hoping what ever axel I got they still fit on properly with out rubbing any idea where I can get the model number for the axel I have so I can try and match it plz
Posted: Sat Jul 17, 2021 9:34 am
by dan@biali
The easiest and most accurate way is to contact a VW commercial parts dept. They will use your chassis number to confirm exactly what should be fitted to your Caddy.
