Hi
Can anyone get me a part number or diagram so I can identify this hose I need to replace
It's the coolant feed into the oil cooler has a small split at the bottom which is causing water to get into my crank sensor plug and caused my running issues
Il get a photo of it in a short while if that helps
Thank you
Oil cooler coolant hose
- Leeoncupra
Lapiz blue pd130 swap with rotiform wheels
Re: Oil cooler coolant hose
Which engine is this on?
- Leeoncupra
1.9tdi doc
Asz engine
Went and took a photo lol
Asz engine
- Leeoncupra
1.9tdi asz doc
Took a photo after my first post to make it easier
