Oil & filter advice
Oil & filter advice
Oil light came on as I set off home from work so had to nip in the petrol station opposite and get a bottle but only had 1l which begs the question would it be worth me having an oil and filter change or a service before filling it up to the required capacity? 1.6tdi & Last service was 9k ago. Seems a bit backwards filling it with fresh engine oil with an old filter.
More to follow
More to follow
Re: Oil & filter advice
I’d be looking into the source of your oil loss first. How much oil did you loose before it put the light on? IMO It depends on how long it’s taken you to do the 9k miles. Myself personally, I do about 9/10k a year in my van. I do an oil and filter change every 12 months.
Tbh I cant remember the last time I checked it so I'd like to think it has just ran out bit will have a nosey just to make sure. 10 months so on par with you give or take a bit and tbf last night i didn't click on how soon my mot will be due so probably hold out till then and get a service done whilst in cheers for the knwodlege swan
More to follow
More to follow
You shouldn't be using that much oil does it smoke or is there a patch under where you park it?
From full to light flashing after 9k in 12 months is excessive loss to say the least.
Unless the garage diddled you and didn't actually change the oil or filter.
Oooh err:/ idk I'll have a look when I finish I cant say I've noticed one and definitely no smoke. And I'd like to think not I get on with the garage very well and used him a while now. Will have an inspection tonight and see if I can see anything. Thanks for the replies and advice guys
More to follow
More to follow
So just got in and checked and theres no signs of any oil leaking and there was nothing on the ground when I moved it so idk
More to follow
More to follow
Speaking to mechanics over the years. I’ve heard some say that occasionally, engines do burn a litre every 1000 miles. Also no two are the same in that respect. That seems excessive to me and I’ve never experienced it personally.
It’s good that you’ve eliminated any oil leaks. I think your next course of action is have the oil changed. Drive right home and check the oil level. (It’ll still be golden at that point so you know it’s new. It’ll blacken up after 500 or so miles)
Then start weekly oil checks. Take photos if you can for comparison.
Okay will do, cheers for that swan
More to follow
More to follow
