Barn door lock
Cuddlycaddy
Barn door lock
Post by Cuddlycaddy »
Minor issue with my rear door lock, when I press remote lock it makes a grinding noise four times but still locks the door, and when vehicle moves off the door makes the grist noise twice EVERY time.
It’s a tad annoying, anyone come across this before is it a strip down and grease up job or a bin it and replace job
Cuddlycaddy
Re: Barn door lock
https://youtube.com/shorts/T1FXe2BFvoM?feature=share
Video to show issue, not actually locking as I first thought
Papa Bear
Re: Barn door lock
Post by Papa Bear »
That sounds terminal. Sounds like stripped gear teeth.
Probably worth a strip down first but I think you’ll need to replace it.
Black
Marmite lover!!!
VCDS
Cuddlycaddy
Re: Barn door lock
I’ve unplugged it and will contact VW for a price Monday
Papa Bear
Re: Barn door lock
Post by Papa Bear »
Try TPS for a new one
Black
Marmite lover!!!
VCDS
Cuddlycaddy
Re: Barn door lock
Will they deal with me if I have part number
Papa Bear
Re: Barn door lock
Post by Papa Bear »
The majority of times, yes.
I’ve bought bits recently with the part numbers and they didn’t even question who I was.
Black
Marmite lover!!!
VCDS
Cuddlycaddy
Re: Barn door lock
£180 + Boris’s bit
Npr_nath
Re: Barn door lock
Post by Npr_nath »
Mine does the same thing! Has done for a while but I just lock it from the inside If you find the part number could you post it please
2011 Red Caddy 1.6 Blue motion | Vmaxx Coilovers | Rotiform Indt 19” | 180bhp | Rear seat conversion
Cuddlycaddy
Re: Barn door lock
Hi I just found one on fleabay for £90 so I’ll give that a punt
Part no.2k0 827 201 AB
Cuddlycaddy
Re: Barn door lock
UPDATE- worked without coding
