3 Antennas on the Ex British Gas Caddy
Evening all.
Can anyone tell me what the 3 antennas are for please?
Cheers.
Cheers.
Re: 3 Antennas on the Ex British Gas Caddy
Trying to post a photo but can I f**k find an app that works for embedded photod
Thanks mate, I'll try that
- robblowen
They're all to do with British gas systems, tracker, computers, etc. I disconnected all the BG wiring from mine and removed the antenna. Then bonded some plates to the underside, filled and painted the outside.
Cheers mate
I have the same although only the studs and cables left behind. They are quite high quality setup and can be used for a number of different purposes, just a pity they are all on the side of the van...
Sent from my POCOPHONE F1 using Tapatalk
Any resale value for these antennas or is it old technology?
- Sean1066
I think if they had any value BG would have kept them
- Gazear
Just ordered some 13.5mm silicon bungs for mine in blue that matches the van so I can get rid of mine.
https://www.ebay.co.uk/itm/Blue-Silicon ... 635-2958-0
2012 LWB 1.6 101 blue. Not a BG van.
Nice one mate, what diameter did you go for?
Took the antennas off earlier then realised I'm left with holes that could let water into the roof lining, so there's a bit of duck tape over them at the minute
Roof rails going on tomorrow evening
Just seen you said 13.5mm...thats not the hole diameter though is it; isn't it M8?
- Gazear
13.5 is the antenna holeJPH77 wrote:Just seen you said 13.5mm...thats not the hole diameter though is it; isn't it M8?
