Hi again all,
I have managed to break the bonnet release lever - just wondering if anybody has replaced the assembly and how easy the job was? Looking at the existing assembly it just looks like 2 screws and the cable lug? Is this correct or is there more to it?
Bonnet release lever
- Papa Bear
Re: Bonnet release lever
Do you mean the lever under the dash itself is broken? That is removed by a clip, if it is just that bit broken it is an easy fix.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
That’s the one - the lever itself has rounded teeth so just slips on the mechanism, I have ordered the replacement mech. That’s reassuring! Thanks
https://www.caddy2k.com/forum/viewtopic ... 22&t=12452
There’s a how to. Not sure if you can view them yet, looks a simple job
Awesome thanks for that, I’ve requested access so hopefully be able to view it soon! Thanks again
- Papa Bear
It’s so easy, I managed it
Need a small flat screwdriver only
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Would you believe - today my van died - injector 2. The AA guy was willing to do the injector there and then for me BUT couldn’t get the “€#%^*^< bonnet open! Fantastic
