I have a Caddy with a ns sliding door only.
I'm currently fitting rear seats into my Caddy -the seats I haven't got a problem with but the B post trims I have.
After removing the bulkhead I'm left with B post trims that are open. I have managed to order the nearside trims but I'm struggling with the off side.
Did you Caddy come with rear seats and only one sliding door?
Did your Caddy come standard with rear seats and 1 side door
- brycieboy
I cut the bulkhead down for sides and trimmed with carpet
Re: Did your Caddy come standard with rear seats and 1 side door
Good idea. But I've taken the floor panel out so the sill trim panel no longer fits.
- brycieboy
I have also taken floor panel out and used mdf in lower bits to house speakers
You can order all of the trim from a Caddy Life.
I was lucky enough to have access to a german VIN number but I will update my build thread with part numbers to make it easier for others doing the conversion
so you have done this?matt_tdv6 wrote:You can order all of the trim from a Caddy Life.
i thought the drivers side b post trim wouldn't fit due to the caddy van not having a door?
another good idea!brycieboy wrote:I have also taken floor panel out and used mdf in lower bits to house speakers
My Caddy has twin sliders so i managed to pick the steps up from TPS for £11+VAT
I have the diagram for the different steps saved on my works computer so ill upload that later
I will update my build thread with pictures when the car comes back from the bodyshop
Cheers matt, look forward to seeing it.
