Low Oil Pressure - Guidance please
AndyBa
Post by AndyBa »
So the damaged repairable 2011 Caddy Max 1.6 TDI keeps putting up a fight against being fixed again...
We noticed the low oil pressure light would intermittantly come on then go off. I rang round a couple of garages but they were just going to "plug it in" and see what VCDS showed. I referred to Google and You Tube and decided to buy a pressure tester off Amazon for circa £20.
Today I fitted the tester and it's registering 24psi at 2000rpm. Less at lower revs.
I changed the oil. Unfortunately there was a glinting of metal in the oil dregs at the bottom of the bowl. I started the car again and I'm getting the same result.
The van has done circa 85K and the condition/MOT history back this up. With it being damaged it didn't come with any history and was a "mis-calculated" risk.
Thoughts/guidance would be welcome.
We have already invested in 2 x new injectors as well as the body repair. I suspect the metal fragments are probably from the engine rather than a failing oil pump?
Thanks in advance.
Re: Low Oil Pressure - Guidance please
Any metal in the oil will be terminal for your engine unfortunately. Was there anything in the filter?
I don't have the information to hand to say if the oil pressure you are measuring is good or bad, seems like good pressure to me.
AndyBa
Post by AndyBa »
Hi Doc. Thanks for the reply.
There weren't any bits of metal in the filter/housing.
The oil pressure light/alarm is obviously on constant now it's disconnected and the pressure guage is plumbed in.
A scan on Google shows one article indicating 29psi may be the VW spec for oil pressure but I can't find a definitive guide to the expected oil pressure at specific engine speeds. I certainly haven't seen the pressure higher than 24psi but I don't want to push my luck.
Scoobysrt
Post by Scoobysrt »
I don't know anyone here that charges to plug vcds did you mean you didn't go to the garage because they would charge you? Maybe there is a member with vcds close to you that would plug in for free.
Have you done a compression test on the cylinders? Is there any slapping noise coming from the engine while it's running?
AndyBa
Post by AndyBa »
Hi Scoobysrt.
I didn't have a problem taking the van in to a garage but was concerned the would rely on VCDS for the outcome and we'd be none the wiser. The original symptons were that the low oil pressure light would come on randomly. Not at start-up and not immediately after and when on wouldn't remain on. I could have just swapped the sensor but thought I'd check by fitting a guage since it would give a clearer picture as to what is going on over a period of time, it doesn't cost much and is 'fairly' straight forward to do.
I could have swapped the sensor out and that may have "fixed" the warning light coming on.
Getting the sensor out is a Pita when you do it for the first time and is made easier by removing the engine lifting hook first.
I'm not sure I know what piston slap sounds like on a diesel engine so I will take it down to the local VW garage this week and see if they can help.
Thanks.
Scoobysrt
Post by Scoobysrt »
Vcds can do live data logging so you could do a journey with it plugged in and see what causes the light to come on, worth a go if you get stumped.
AndyBa
Post by AndyBa »
So today I rang Autohaus Dolby. Matt advised me that the oil pressure should be 2.0 bar which equates to 29psi and no higher. 24psi not being good.
AndyBa
Post by AndyBa »
I did a bit more fault finding.
I took the sump off to see what the state of the oil pump was. It looks absolutely fine with no visible sign of wear. Bottom end looks really clean with very little evidence of metal "grit". Also checked the state of the toothed drive belt. Noted it is a DAYCO belt with a date of 2017 no teeth missing. Note the van is 2011. So there has obviously been a previous issue and it looks like the pump has been replaced too, it makes a nice squelching sound when rotated. I checked the big-end bearings for movement. Minimal side to side and no up/down. I'm tempted to check the state of the big end and mains whilst I've got the sump off, never done it before. Assume the bolts will need replacing?
I do realise there could be issues on the top end/turbo due to low oil pressure, but surely the main cause is the bottom end and if all is good then the top end will need checking. I haven't done a compression test but the van doesn't seem to be lacking power and doesn't smoke.
Your thoughts would be helpful.
Exuptoy
Post by Exuptoy »
I’m not a mech but at 50yo and been around cars all my life, when you have the sump off I’d suggest dropp off the bearing caps and carry out a cursory check of the shells. Pop them out of the lower half of the cap and carry out a vernier measurement to check for ovality.
I generally wouldn’t expect much movement and if it were enough to feel it that would suggest it’s Fubar so at least you know.
Check for scoring on the shells and measure at 3 points to verify it’s not oval.
AndyBa
Post by AndyBa »
Okies. So have removed the oil pump, all the big end bearing caps and one main bearing cap. The crank has previously been "fettled" all the bearings have + 0.05
EDIT 0.5 stamped on them.
EDIT: Bearings and crank are fine.
Got all new bolts but now need to know the torque settings. Can anyone help please? VW won't tell me!
Thanks in advance.
Exuptoy
Post by Exuptoy »
Speak to a local garage, most have access to Autodata.
Exuptoy
Post by Exuptoy »
Just googled and found this. I know it’s Golf and Jetta but covers a few engines like BLS etc.
http://mrtn.m4ti.net/mk5/Jetta%20&%20Go ... jector.pdf
Edit
Sorry just realised it’s a 1.6
Here ya go.
https://forums.ross-tech.com/index.php?threads/5126/
AndyBa
Post by AndyBa »
Thanks Exuptoy.
Exuptoy
Post by Exuptoy »
My pleasure, hope it helps. That’s what these forums are for👍
AndyBa
Post by AndyBa »
So today I finished fitting the sump. I think someone at Haynes is having a laugh if they think you can apply the silicone sealant and bolt all 20 sump bolts and 3 trans-to sump bolts in 5mins whilst laid on your back under the car!
A few torque settings for the 1.6 now I've invested in a manual. I don't know why but I thought they'd stopped publishing manuals!
Main bearings 65Nm + 90deg
Oil pump 3 x bolts 16Nm
Oil pickup 2 x bolts 9Nm
Sump to block 20 x bolts 13Nm
Trans to sump 3 x bolts 40Nm
I have left the 2 awkward angled "sump bellhousing" bolts off pending ideas on how not to lose them! I tried twice and they went AWOL.......PITA.
Manually turned the engine over to prime the oil pump prior to starting. Obviously no change on the low oil pressure front.
Doing any cylinder head check looks like a nightmare over and above taking the rocker cover off. The cams are held in a "tray" Probably another symptom of making car manufacture modular to make it quicker and cheaper.
