Clicking noise behind dash
PeteS
Post by PeteS »
Hi all,
Hopefully this will be a quick fix
When I turn on ignition or turn on fans, I get a clicking noise behind fan control/dash for about 10 secs, any ideas lads ?
Pete
Re: Clicking noise behind dash
Which generation of Caddy do you have?
2004-2010
2010-2015
2015-2020
PeteS
Post by PeteS »
Ah yes sorry Doc, 2016 mk4 2.0
I would post a video but I’m rubbish with computers :D
Does your ventilation control work as it should?
Moves to the correct outlets? Heats and cools?
Sounds like a servo has come off or lost its position calibration.
PeteS
Post by PeteS »
Fan speeds and air con all work ok, cool works fine but don’t know about heat, it also happens first thing when ignition is switched on but fans are off.
Will do a search on here for servo issues, thanks Doc
Mickthebell
Post by Mickthebell »
May be recirculation flap, have a look on youtube
BowCaddy
Post by BowCaddy »
It’s probably most likely the recirculation flap motor as above. They break open and cause the noise mentioned. See if you can have a look from under the dash in the passengers footwell you may be able to see most of the control motors you have a distribution motor a temperature motor and the recirculation motor. If you can get someone to operate the control whilst you look it may help you pinpoint the location of the noise
Sabbunsingh
Post by Sabbunsingh »
My 2016 did this. Stupid recirculation flap motor. I managed to get my hand up and disconnected it as its was annoying. Not had a heating or ac issue and it's on the list of silly things to fix. Seems like a right pain on the arse to do.
Philt32
Post by Philt32 »
Read this thread a couple of days ago and low and behold….mines started making the same noise today
Muddymoto
Post by Muddymoto »
Does anybody know the part no as Mine is toast now
Plumber
Post by Plumber »
I have the same problem
Servo motor air recirculation flap
1K0907511Q Older
5Q0907511H Newer
Mine is a valeo brand motor and brought the replacement from autodoc, 40-50£. Its not an easy job and is on the to do list
Caddy-Chris
Post by Caddy-Chris »
I have a 2018 reg Caddy maxi life with this issue. Just spent an hour upside down balanced on me head and shoulders with my arms up the back of the footwell and found the flap motor right at the top of the blower housing. What a pig to get to!
After faffing around I got the flap motor thing detached but no amount of wiggling it would get the thing out of the dashboard prison.
It looks like a total lower dashboard removal to get to the damn thing. Has anyone done this themselves or know how much it cost for a garage to do it for you? I have panel tools but could do with a guide or something.
Thanks!
Caddy-Chris
So I got the faulty motor out today without stripping the entire dash. I just did a bit of cutting through the plastic panel behind the glove box. New motor ordered. It was still a fiddley arse to get the thing out but I'm glad I didn't have to spend a small fortune in VW labour for such a trivial repair.
I learned along the way that most parts sites call the motor a "blending flap" motor or servo.
It's so nice to have the thing unplugged so I don't have to hear that clicking every time I turn the key!
bigblackbetty
Post by bigblackbetty »
my 2016 just started making this noise as well, clearly recirc as reverse, washers and on off cause it. having zero access behind the glovebox I asked VW about it and they say replacement involves whole dash removal, 8 hour job. ill chop my dash thanks!!
anoneamus
Post by anoneamus »
I was unlucky to have this, but fortunate enough to have invested in extended warranty from the dealer (have had car since new). They covered it. :D
