Caddy 2015 Cruise controle problem
scirocco1600
Engine size/power: 2.0 CNG (107bhp)
Post by scirocco1600 »
hello ,
we have a Caddy 2k 2015 ( 2.0 Ecofuel ) , the caddy was a Non cruise control -non MF steering car .
now i installed a Cruise controle handle and a MF steering wheels .
mf works fine ,
cruise control do not work ( Communication problem )
now a saw this topic about a (caddy cruise wire) communication wire (viewtopic.php?t=36535) is this for the 2015 caddy also the same as the 2008 caddy ?
i have also another little problemen , i orderd for the mf steering wheel a airbag , now a have a airbag fault ( low resistance ) , can this be solved?
Andre-desmo
Re: Caddy 2015 Cruise controle problem
Post by Andre-desmo »
Hello,
finally someone with ecofuel :) (mine is 2012).
I made same upgrade, added entire levels block. With vcds, insert code for cruisecontrol plus, under steering wheel menu, added cruise control on level. Searching on youtube, found information searching golf 5 and 6 retrofit.
If you are using MF steering, you need right level without button for dashboard menus.
Some videos show repin, not needed on caddy 3
