Anyone fitted a complete strut from a Mk5 golf?
Exuptoy
Post by Exuptoy »
Just wondering, if anyone has fitted a complete strut including the hub from a golf?
Reason for the Q, I have a full set of Stance plus coilovers on my Mk5 golf and would like to swap the struts between the caddy and golf and put my old caddy strut (which has new springs and top mounts on to the golf and get the coilies in to the front of the caddy.
I know the strut is probably 55mm but my thinking is whatever size is on my caddy I could swap the complete assy out including the hub. I know the rears won’t fit but I can just get some cheap standard shocks for the golf and leave the rear spring in place.
They’re only about 4 months old.
Giddy
Re: Anyone fitted a complete strut from a Mk5 golf?
Post by Giddy »
Why all this hassle? Stance+ only do 50mm struts and use adapter sleeves to fit 55mm hub, so will fit both size hubs. Also, what you gonna do with the Caddy rear? Still gonna need a shackle kit for lowering. Would be better off just to get a Caddy specific Stance+ kit.
Sent from my Pixel 4 using Tapatalk
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Beggsy
Post by Beggsy »
Yes they fit 55mm dia
Exuptoy
Post by Exuptoy »
It’s ok, didn’t think of the hub incompatibility.
I’m gonna get Stance front and already bought the weld on plates from Retrofication so I’ll still need stance shocks and drop plates. Not gonna go with the full shackle set up as these brackets supposedly save 6kg in weight and I shouldn’t need the relocation plates.
Have I got that right?
rodmax
Post by rodmax »
Yup :D
I used the retro kit and mk5 gti front coilovers and short rear shocks , drives perfectly
Exuptoy
Post by Exuptoy »
Cheers @rodmax did you buy the drop bars from retro too?
rodmax
Post by rodmax »
Hi
No i bought just the plates from them. I put adjustable front drop links on mine. I got these off poobay :shock:
Exuptoy
Post by Exuptoy »
Cheers fella. I’ve contacted stance for a part kit of Coilovers, drop plates for the height adjustment and a pair of short shocks.
