audi s3 tt vents upgrade help
has any one got a link to the 3d print of the extender we use when we mod to fit the later s3 vents
Re: audi s3 tt vents upgrade help
I dont know of this massively helps as I haven't actually fitted them yet so cant comment on how good they are but I ordered the rings and adaptors off this seller on ebay for the 8p vents, all looks okay i just haven't been to buy needle nose pliers yet to remove the vents
https://www.ebay.co.uk/itm/VW-CADDY-VEN ... 635-2958-0
More to follow
More to follow
Hi
I also purchased the rings and adaptors of that ebay seller and can confirm they worked a treat.
@rodmax was that for the 8p vents?
More to follow
More to follow
Hi
it was
it was
I dont mean to hijack the thread but would the original vents go back in as they came out if I didn't like the 8p vents? The reason I ask is I dont know if I'm 100% on swapping the vents out, bought them quite spontaneously as I got the full set rather cheap
More to follow
More to follow
any one got any photos of this been done mines a 2014 ?
So are the 8p straight fit ?
Nope... part of the original caddy vent is needed also the 8p vents fit better if they are put in upside down.
so you will then have to change the internal blade's around which is not hard to do.
Nice one
I'm sure the latest gen s3 go straight in as theyre bigger but could do with the adaptor thing for maximum efficiency which the seller I linked does sell. As for the 8p if you dont want to cut your caddy vents the link i posted is a plug and play adaptor kit to avoid this. Rodmax as previously said they work a treat but I'm yet too find out because they're stuffed in a drawer
More to follow
More to follow
These look really impressive..
Nice find
Nice find
