Retrofit mfsw with cruise control
Hi peeps,
I was wondering if anyone out there would be able to help me.
I have installed a polo mfsw with the cruise control buttons on the wheel to my mk4 midline caddy, as far as I know I just need to change the slip ring and then code it all in.
What I don't know is what slip ring I need iv been searching multiple sites for over a month now and still no closer to success .
Iv been told that there is only 1 slip ring that will do the job, is there anyone on here that is happy to tell me which slip ring I need?
Many thanks
Many thanks
Re: Retrofit mfsw with cruise control
Have you bought and fitted a module from Spacewalker? You’ll need this before anything if you want your cruise to work on the wheel.
I can’t help on the skipping type, sorry.
I was told the module is built into the slip ring on the mk4s ?
I don’t think that is correct.
Have a look at the ‘multifunction steering wheel talk’ topic.
Okay thanks I'll try find it, still pretty new on here
- spacewalker
If you not provide vcds autoscan you will not get right direction to what /where to look.
Okay, I should be able to post tomorrow as friend has it on his work laptop,
This is what he sent me, is this correct to what you are asking for spacewalker?
Save it as a text file, then copy and paste it its a lot easier mate.
