18" inch steelies
18" inch steelies
Whilst I'm waiting to given access to the other areas of the forum I'll ask in here.
I'm currently running 18"alloys and keen to run steelies. Who is running 18" steelies and what do I need to consider when bolting them on?
Sent from my SM-G991B using Tapatalk
- Guy94
18" inch steelies
Welcome to the forum Andrew. Not sure if you have done much research, the only company I came across that made 18inch steels in 5X112 was JBW. Personally I had nothing but trouble with them, they sent the wrong wheels and had imperfections on every one. I know others running them so perhaps they had a better experience. You will just need spigot rings with those wheels.
I ended up buying some 18inch VW Golf space savers and got them banded. Certainly not a cheap option but they look great. Bolt straight on without the need for spigot rings.
Re: 18" inch steelies
Wow, those look awesome!
I wanted to get the banded wheels wasnt tosure on et off sets with the van being slammed deep dish offset ect they do look cool tho
- Guy94
Think mine are about ET40ish. Would have loved to have gone lower offset, just not possible without modifying the axle
Re: 18
Lower pushes the wheel out doesn’t it and how wide are yours
- Guy94
@bassvanman yes buddy, 8.5
Re: 18
What defect were you jbw wheels as I was looking at those
- Guy94
So on the face of 3 out of 4 wheels, I can only describe it as angle grinder marks... not sure how they got there but it as clear it was before they were painted. And the quality of the powder coat also left a lot to be desired.
Aww not greatly manufactured then I expect. I guess they are seen as steelies so probably not much care put into them nice heads up can banded steels take a fully laden van
Cheers for sharing a pic. I've found a few online. Guess i need to sift through the shit. What did it cost to band the space savers?
Might go that route as the costs I'm seeing for ready mades are already pricey
- Guy94
18" inch steelies
@bassman It’s not some thing I would feel comfortable with advising, due to the possibility of human error with the welds - however I have had no issues.
@andrew £747 inc vat I supplied the wheels. Went to Duchy Banded Steels, incredibly highly rated on the Transporter forums, is work and finish is unparalleled!
Cheers Guy, they're only a 30 min drive from me. Will tap up Combellacks for some spacesavers
